1 - 8 of 8 Posts
just a quick Q: I'm getting lazy at this point after going all the way to bare metal and I was just woundering if I go over the bare metal with 120 do I need to block after a couple coats of 2k high build?
I"m doing etching- 2 wet coats
2k-2 wet coats
base-3 wet coats
clear-3 wet coats
G
get a yard ruler and wrap it with the 120 grit paper press it againest the car and sand back and forth it will get it straight
G
thats true the guide coat works great it changes color as you sand so you don`t sand to much in one area the color i seen went from blue to gray as you sanded
i didnt know they had that shit...most just use black paint
okay... I have shaved my tailights door locks and handls I also did a headlight swap involving my shaving my turn signals and I have glazed all dings in the metal... the body as been take to bare metal except for door jams and under the hood, I just scuffed that area. all the places that I have done body work on have had great care as to what I'm doing... tack welding fiberglassing bondoing under 1/8 in thick.... so I have went back over the body with a DA and 120 and thats where I stand
1 - 8 of 8 Posts
