1 - 20 of 26 Posts
its a boss chaos 550 (800 peak mosfet) sounds good, and im running 2 pioneer 400 peak power 10's on it, with a kenwood reciever.
well when i hooked up my ride (2002 ford focus) i was runnin a 150.2 lightning audio amp (power by rockford ) with 2 10 inch rockfords. i bought the 2 pioneer 10's for 30 bucks (with a probox box) and then i traded my rf 10's and my Lighing amp for the boss amp and at first it didnt over heat or anything and it ran good. i mounded it to the fold down back seat and it over heats regardless if the seat is open or closed. and i dont know why
can someone please help?
HOME BREWED, NO HELP
#1 its a boss
# 2 . see above....
Originally posted by candymancaddy@Aug 27 2006, 05:55 PM~6054020
#1  its a boss
# 2 . see above....
lol this could be true
they recommend to mount amps on a verticle surface if in the trunk at have space in front of the amp so that air can move over it's fins... also, check your gains, your grounds (weak grounds will cause your amp to get warm from my experience) and your wiring... if you have a pinched speaker wire and its making slight contact with metal, then your amp will get hot and go into protection...
i had the same problem back when i was rockin power acoustik and it was a pinched speaker wire...
right now i have it to where my speakers arent jumping out their box
i have the gain and frequency set to where you can hear a nice bass tone
my homeboy had that same amp in his caddy and it never over heated on him
i think im going to buy a new amp kit and mount it elsewhere and see if the problem persist
i know its a boss amp but it pushes alot of bass
ima reground it in a little bit and see how it performs
so like do i un bridge the subs and then add a little more gain?
cuz ima try it and see how that works and how it handles
I RAN THOSE SUBS BRIDGE TOGETHER
SO I HAD LEFT POSITIVE AND RIGHT NEGATIVE RUNNIN TO EACH SUB
regardless of how you ran them, we need to know the ohm load per sub and what your amp can handle
IE:
(2) DVC 4 OHM subs
and your amp says "2 Ohm stable stereo"
Now that you have an example we need the specifics or the model #'s to actually give you any useful information.
CH550
2 Channel MOSFET Bridgeable Power Amplifier
with Remote Subwoofer Level Control
Max power, 2 ohm
400w x 2
RMS power, 4 ohm
125w x 2
Bridged Power, 4 OHM
800w x 1
Signal-to-noise-ratio
102 dB
THD
0.01%
Dimensions, LxWxH
11 1/4” x 11 3/8” x 2 11/16”
the info on my amp
Originally posted by Sleepy G@Aug 28 2006, 09:35 PM~6063069
CH550
Max power, 2 ohm
400w x 2
RMS power, 4 ohm
125w x 2
800w x 1
102 dB
THD
0.01%
Dimensions, LxWxH
the info on my amp
and what brand/model subs?
Discussion Starter · #13 ·
2 pioneer TS-W10C subs
thats your problem, you have single voice coil 4 ohm tens and your trying to run them at 2ohms bridged.
unwire your subs, run one to each channel instead of bridged. it wont sound nearly as good, but your going to fry that amp eventually the way you have them hooked up.
Discussion Starter · #15 ·
im runnin them un bridge right now and you can tell the difference :( but o well ill get me some better shit later on
i was think of switching to a bandpass instead of my probox or putting those 10's in my cutty and buying one 10 that will sound good with that boss amp
what would u recommend for that amp? im trying not to break the bank
so basically i need something that pushes 400 rms at 4 ohms bridge and/or a sub thats 800 peak bridge and 4 ohms?
Discussion Starter · #17 ·
im thinking one Pioneer 12" TSW301R (800 peak, 150 rms, 4 ohm) 80 bucks
or a kenwood 10'' KFC-W2510 (800 peak, 350rms,4ohm) 100 bucks
if you want to run with just 1 sub, go for something like kicker L7, jl, or higher end rockford. same for the amp. you get what you pay for. i run 1 12"rockford HX2 and 800 watt rockford amp in my acura and i never had a problem and it sounds great.
well if u kept those subs, you would need an amp that is stable @ 2 ohm mono, preferrably a moboblock class D amp.
I think a JBL BP600.1 or a Directed 600D would easily make those cones bang!
Now if you went with new subs, I would choose a decent sub that had Dual (4) ohm voice coils. That would expand your wiring options, which would in turn expand the amps you could use.
hehe, im gonnaget some shit for this, but i dont give a fuck.
if your lookin for a ghettobudget ass 10 that still beats hard, pick up one of those mtx RT-10'S. you can pick them up on ebay sometimes for .99
everyone hates mtx and i do for the most part, but i have 2 of those RT's and i really like them for budget beat. i got both of mine for a combined price of 25$ shipped and i know i could turn around and sell them to some punk kid for more than that.
budget amps, you know im gonna recommend a planet audio refurb off ebay. 850w monoblock amp, http://cgi.ebay.com/PLANET-AUDIO-850-WATT-...7QQcmdZViewItem
little over 100$. nice amp, i have the 1250 of the same series and love it, plus it leaves a little room for you to upgrade your subs later.
http://cgi.ebay.com/MTX-RT10-04-10-400W-CA...1QQcmdZViewItem
there is an mtx rt-10, its a ghetto ass sub, i have them tho and i beat the shit out of them and they do hit a little bit in the right enclosure. im gonna take some shit for recommending these probably, but as i said in other posts, i wouldnt recommend anything i wouldnt use myself. if your looking for something very cheap that beats, the mtx rt-10 will do well.
1 - 20 of 26 Posts
