Originally posted by CustomKid69@Jul 31 2005, 08:16 PM
$700-$800 for Interiors.
Components up front
back dash (6x9 or 6.5)
Amp to run whats above.
Please let me know what is the best i could do with that amount.
[snapback]3516452[/snapback]
so your saying that your willing to spend 700-800 dollars on a component set for your front doors or kick panels, and on the back dash either 6x9's or 6.5's...
if your going to spend that much on a 2-way system (subs will make it a 3-way) i suggest you uses kick panels to house your 5.25" or 6.5" components up front, and place the rear 6.5" components in the rear doors instead of on rear dash...
get a good 4-channel amp that does about 60watts x 4 @ 4ohms and your gonna be LOAD and depending on your power source/amplifier/HU/and comp set your gonna be CLEAR & PURE....
even if you get speakers that can handle maybe 90wattsRMS, 60watts RMS will be plenty, you have 4 of them, and depending on the quality of the compset, you might not even take the volume passed 50%...
and you mid as well spend the same amount on maybe a single sub/amp combination...
-qs
