1 - 20 of 27 Posts
can this still be repaired and reinforced?
i got a donor car sitting in the garage, just dont have time to swap it around. I just need a quick fix til i can get around to doing it properly
ya you need to bend that back weld it up and put a 1/4" plate inside before it rips all the way threw
having troubles trying to get it to line back up. .
any suggestions?
just a few months. .
if you're thinking about juice, think about reinforcing first. do it once do it right.
what ride you juicing?
Mine cracked in the same spot on my caddy we used some heat and then just hammerd down on it. welded it then wrapped the front with 1/4 inch plate
before
after
Sorry for the size of the pics bro don't know how to make them bigger :cool: temp fix i'm working on a new frame don't like the idea of riding on a frame that was cracked before :angry:
Discussion Starter · #14 ·
Damn, and i thought mine was bad. Nice work with the repair :thumbsup:
Yeah, I'll be working on a new one when I get it off. But being a sub-frame (not a full frame, only goes to after the front doors) it still wont be as strong as a full frame.
Discussion Starter · #17 ·
Good thing with that is its a common car to juice. All the info is already out there. With mine being an Aussie car, its never been done before. . Its trial and error.. Cutting springs, cylinder clearance, weak points, etc
Originally posted by raki@Dec 7 2008, 06:43 PM~12362226
is that welded underneath too?
As much as we could with the car on the frame top bottom and sides just wanted it strong enuf so i can roll while we do a complete frame this is our first time so it's not show quiallity but hopefully the next one will be!! :cool:
1 - 20 of 27 Posts
