Originally posted by 67impala@Sep 27 2003, 06:32 PM
so there is what like a couple buttons that you hold down for 3 sec's? to get the options? i found it very user friendly and simple to navigate and the amount options and shit you can do is unreal...
I'm sure that pioneer would blow that alpine out of the water.
Built-in DSP with PRO Mode
13-Band Graphic Equalizer
Frequencies: 50, 80, 125, 200, 315, 500, 800, 1.2k, 2k, 3.15k, 5k, 8k, 12.5k
Level: +/- 12dB
5 Factory and 2 User EEQ Presets: Super Bass, Powerful, Natural, Vocal, Flat, Custom1, Custom2
Source Custom EQ memory (Independent Custom Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
Auto-EQ (3 Curves, Microphone Included)
Digital Sound Field Control (4 Presets)
Octaver Bass Enhancement (2 Modes)
BBE (+/- 4 Step)
Time Alignment (4 Modes, 1 Custom): Adjustment range 0-160inch/1 inch steps
Digital Automatic Sound Levelizer (ASL) with Built-in Microphone (5-Mode)
Two-Way Crossover Network (Normal Mode)
Front HPF: 50/63/80/100/125Hz, Slope -12dB/oct
Rear HPF: 50/63/80/100/125Hz, Slope -12dB/oct
Subwoofer LPF (Mono): 50/63/80/100/125Hz, Level -24 to +6dB, Slope -18dB, Phase (Normal/Reverse)
Three-Way Crossover Network (PRO Mode)
High HPF: 1.6k-20kHz, Level -24 to +0dB, Slope -12 or -6dB, Phase (Normal/Reverse)
Mid LPF: 1.6k-20kHz, Level -24 to +0dB, Slope -18/-12/-6/0dB, Phase (Normal/Reverse)
Mid HPF: 20-200Hz, Slope -18/-12/-6/0dB
Low LPF (Mono): 20-200Hz, Level -24 to +6dB, Slope -18/-12/-6dB, Phase (Normal/Reverse)
IP-Bus System Control
MCD Control
TV Tuner Control
Auxiliary Input (CD-RB10 or CD-RB20 required)
2 External Unit Control
S.L.A. (Source Level Adjustment)
Selectable Fader Control
Hi-volt RCA Preouts (x3 pair, Front, Rear & Sub) (6V)
Advanced Organic EL Display (256x80 pixel)
Full-motion 3D graphic animations including:
4 screensavers (High Dive, Dune Racing, Apollo Mission, Extreme Skiing)
4 Spectrum Analyzer displays
5 background full-motion animations
12 background pictures
Enhanced Clock mode & Off (text-only) mode
2 Display Modes (alternate screen layouts)
Form 1 includes 32-character text display capability
Form 2 includes 2 lines of 24-character text display capability
Adjustable brightness level (32-mode)
Customizable Display Download Capability
Cellular Mute Capability
All that in a single DIN unit....now that, is unreal
