1 - 8 of 8 Posts
do i need coils from a hydro shop?????
or can i use ones for a better ride?
rite now i got 4ton cut real low and one 2ton in back cut in half.........
if i left less coil on them would it be better?????
i pretty much know ton size matters and shit....just wanna good answer....cuz most the time ppl just say "yea" when I or some1 have asked multiple questions. :)
How many batts do you have? Usually 1 2 ton coil cut in half make for a pretty good ride as long as you have 6 to 10 batts and with shocks also! ;) In the front
I wouldn't go over 3 tons for a good ride and make sure they are at least 5 to 6 turns! ;) You could use accum. for the front or have some shock brackets made! ;)
8batts...
when i raise the rear...it bounces a lot.....when i had the stock fronts back there....it didnt :dunno: it went up smoother and also seem to ride better, if memory serves correct..........the front.....broke in too much and it sits too low and rides bad....im thinkin 3ton up front wit only a few turns off....
how many turns is on a full stack?
heres what i was thinkin..................if i keep my car.....i would want to get coils that make it a lil lower......but where i can take out the pumps/batts and drive it with the oil outta the cylinders....makin it low..........but not too low...........thats why i wanna good ride. :cheesy:
1 - 8 of 8 Posts
