G
its in a 98 cavalier...fitting keeps leakin, changed fittings 2 times already but im running out of ideas. hose is ok and its only the pass side front. thx :)
G
thanx i will try it... but i think its just shaking loose from turning. but it doesnt make any sense cause its just one side.........
THE REASON IT WILL LEAK IS BECAUSE EVERY TIME THAT CAR GOES UP IT PUTS PRESSURE ON THAT FITTING A SWIVEL WILL HELP A LITTLE BUT WHAT I NORMALY DUE WELD THE CYL SHAFT TO THE 360 MOVENMENT BRACKET THAT IS ON TOP THAT WAY IT MOVER WITH IT NOT JUST THE SHAFT THAT IS IF YOU HAVE A CCE KIT THO
