ok i think i put on spark plug to the wrong post, i was doing good, but then i seen two plugs off at the distributor and think i fucked them up, i just need to know how the distributor fires them so i can match them up with the block, i see the numbers on the block but how do i match them with the distributor?????? i dont see no numbers on it???? :(
I would do one of two things, call autozone and ask or just walk in and open you haynes book for free anc check out the firing order on the cap. Thats simple.
Originally posted by 216RIDER@Oct 31 2003, 05:57 PM
18436572
Number one cylinder is the
FRONT LEFT (Drivers Side) cylinder
You'll need to pull that plug out, have somebody put their finger over the hole and just bump the ignition until you feel air being pushed out.......then take the cap off and see where the rotor is pointing.....Whichever post on the Distributor cap it's pointing to will be #1.......then wire it up using 216's reference!
L8
