INDIVIDUAL
I want to run 10 or 12 batts But i heard the pump mount for the piston pump has to be thick can any one help me out post pics or info im building a town car thanks. :biggrin:
Originally posted by SERIOUSHYDROS@Mar 19 2010, 12:18 AM~16934152
only difference on a piston pump would be if you were running a large steel block. Then you would want a strong mount because of wieght. But other than that a piston pump mounts the same as any other pump.
a piece of 1/4 angle iron will work for a pump mount.....i however did my mounts off the rack then came back and link it all together on the back side to make sure theres no flex
INDIVIDUAL
I have a Hi-lo Block with a 1in port heavy as FUCK.
