1 - 10 of 10 Posts
True-S Mike
ok, i seen that i have an extra wire in my switch cord i bought from pro hopper....the color of it is black, what is this for?
2)***** does it matter what switch you start wiring first. the first or the last? how i have it.....it goes from battery to the front pump/dump switch, and ends at the rear right 3 wheel.
is this ok...all the diagrams i have start it at the last switch but need to know if it matters.
please help, i dont want to continue till i know for sure
1. how many pumps and dumps are you wriring?
2. is the cord 7 or 9 wire?
3 how many switches/moves do you want?
True-S Mike
ok, i have a 9 wire cord but was looking at a 7 wire diagram....so i know what the extra wire ( s ) are for......zzzzzzzzz :uh:
any way:
i have 2 6 pron and 2 3 prong ( fr,bk, 3 wheel ).
i wired it so the 24 volt wire gos to:
front-back-left 3- right 3
will that be ok?
my diagram goes like this:
24 volt- right 3-left 3- back- front.
does it make a diffrence??????????????
i have a 2 pump, 3 dump system
okay you have a 2 pump 3 dump system. You will be only using 6 wires (of your 9 wire cord)
1 - 24 volt
1 - front pump
1- back pump
1- front dump
1- back left dump
1 - back right dump
I'm assuming you are going on dump to the front.
It doesn't matter which colors you use for what: ie;
black - 24
white - front pump
blue - back pump
orange - front dump
red - back left dump
grey - back right dump
This is just a suggestion.
Hope this helps you.
Later
TC
True-S Mike
1 - 24 volt
1 - front pump
1- back pump
1- front dump
1- back left dump
1 - back right dump
black - 24
white - front pump
blue - back pump
orange - front dump
Later
TC
i am aware of that, thanks though, but does it matter witch switch it hits first comin from the 24 volts? front ( first on the panel ) or r 3 wheel ( last on the panel ?
im starting t think it doesnt matter though
i have my 24 volt goin straight to my front switch ( first on the pannel ) then branching off to the rest as well as my pumps / dumps -be it - front, back
is this ok?
u can wire em in any order u wish and if ya quit smokin that shit u might b able to word yourself better syke u know how long it took me to post this and im bent :puffin:
1 - 10 of 10 Posts
