OK fellas..Ive called and went to every part house in town and am having no luck finding the starter..The number shows it as a delco remy 1108504...The ones there trying to give me bolt up to the engine from the bottom of the starter but mine bolts up from the face and has three ears..IM lost..Ive added a few pics..
"Old School DJz"
35259580 - Heavy Duty Starter Motor
  • 3D Photo
  • Front Photo
  • Rear Photo
  • Side Photo
  • Front Dim Drawing
  • Rear Dim Drawing
  • Side Dim Drawing
  • Output Curve
  • Wiring Diagram
Previous | Next
Product Specifications SpecValueItem number35259580Sales numberN/ASeries numberM93NotesSupersedes #35258810System voltage12kW3.0Mounting styleFLANGEDimensions inMILLIMETERSRotationCLOCKWISEHousing coatingRAWUL ApprovedNoPinion teeth10Pinion pitch10/12Pinion OD32Pinion PAR34.7Switch position-46°Ignition terminalM5X0.8Battery terminalM10X1.5Distance to teeth12.31Flange ID162
Availability RegionPriority / StatusUSA / CanadaLimited (W)United Kingdom / EuropeLow (C)
Parts Breakdown Title / LinkDescriptionM93R Series Starter Motors - Ver 1Listed units serviced
As listed
Rev 2/15/01
M93R_parts_list.pdf (285 kb)
Numbers Our Customers Use
CompanyPart numberSAS UNITSSM134SPAREX LTDU.35975SPAREX LTDU.36107
Cross Reference Numbers
CompanyPart numberCommentAAP6570 AAP6601 ACCUTEK/KNIGHTS1386 ACCUTEK/KNIGHTS1480 ACCUTEK/KNIGHTS8217 AEPSND0044 AEPSNK0007 AEPSNK0029 AES NEW3838AN AES NEW6570N AES USS7072N AIMSN-0010BR AMPERE31659 AMPERE4000S AMPERE4321S ANDRE NIERMANN01362312 ARROW34-1021 ARROW35-1021 ARROW35-1934 ARROWHEAD3663WS BECK ARNLEY187-6015 BOSCH0.001.358.041 BOSCH0.001.359.016 BOSCH0.001.359.090 BOSCH0.001.362.312 BOSCH0.001.362.316 BOSCH0.001.367.037 BOSCH0.001.367.075 BOSCH0.001.369.001 BOSCH0.001.369.005 BOSCH0001358041 BOSCH0001359016 BOSCH0001359090 BOSCH0001362312 BOSCH0001362316 BOSCH0001367037 BOSCH0001367075 BOSCH0001367078 BOSCH0001369001 BOSCH0001369005 BOSCH0001369022 BOSCH EXCHANGE0.986.012.420 BOSCH EXCHANGE0.986.014.730 BOSCH EXCHANGE0.986.014.740 BOSCH EXCHANGE0986012420 BOSCH EXCHANGE0986014730 BOSCH EXCHANGE0986014740 BOSCH EXCHANGEBX1242 BOSCH EXCHANGEBX1473 BOSCH EXCHANGEBX1474 BOSCH EXCHANGESR901X BOSCH-REMANSR-526X CARGO111221HC CARGO111755HC DELCO10461471 DELCO10479628 DELCO10496870 DELCO10496885 DELCO1107119 DELCO1107120 DELCO1107340 DELCO1107352 DELCO1107385 DELCO1107577 DELCO1107599 DELCO1107863 DELCO1107871 DELCO1108320 DELCO1108326 DELCO1108327 DELCO1108331 DELCO1108351 DELCO1108354 DELCO1108371 DELCO1108392 DELCO1108420 DELCO1108433 DELCO1108490 DELCO1108497 DELCO1108499 DELCO1108504 DELCO1108507 DELCO1108521 DELCO1108743
so far nobody has this specific starter anymore... Presto-lite & others make one that will fit... I got mine from autozone/ the 1st one I got didn't fit but the 2nd one did... good luck homie... keep ridin':puffin:
"Old School DJz"
I keep forgetting I have a 400 small block in my 63... my starter is a "Duralast DL3510S" that I got from autozone... I don't think you are gonna find one like the exact starter on your ride now, but you might find one close to it. Check with Napa auto parts they should have something close. Keep Ridin' :puffin:
