1 - 19 of 19 Posts
jus got a gf2 pumphead #11 put it on and jus over spins anyone know whats wrong
jus spins no fluid
thats what i thought got a new one and still the same shit
are you sure you got enuff oil in it ...and or right size pressure seal?
Originally posted by KINGLOWNESS@Aug 22 2005, 06:40 PM~3671660
Yeah there should be 3 plugs in that head Make sure you remove ALL of them
either that or his check valves are backwards :0
True-S Mike
Originally posted by ExplicitDesignz@Aug 22 2005, 10:25 PM~3673198
When you guys are talking about torqueing (sp?) these, is this from the head TO the block? Or what?
yes, all 6 bolts needs tourqed with a ft pounds tourqe wrench. be sure all 6 are the same in a criss cross pattern
I Could be wrong but I have Built probably 500-800 Pumps If memory serves me it should be 22-26 lb Torque
1 - 19 of 19 Posts
