in parellel... pos to pos, neg to neg.Originally posted by IBEJOKER@Nov 13 2008, 10:35 AM~12144228
I HAVE TO OPTIMA BATTIES SHOULD I HOOK THEM UP IN PARALLEL OR IN SERIES THERE GOING TO BE FOR 4-12 AND 4 AMPS
what amp rating should the fuses beOriginally posted by Sporty@Nov 13 2008, 02:57 PM~12147872
make sure your using inline fuses on both ends if your going to be running one batt underhood and another in the trunk..
I'm pretty sure there's some more information in here:
http://www.layitlow.com/forums/index.php?showtopic=169119
If not, you can do a search in this forum to bring up some threads about this.
depends on the strength/ output of your alt. If your alt is putting out 300a and you have a 150a fuse... nawsayin?Originally posted by CAPRICE2LOW@Nov 13 2008, 04:21 PM~12148095
A GENERAL RULE IS THAT YOU FUSE THE RATING OF THE POWER WIRE. COMMON SENSE FROM THERE. I MEAN 300 AMPS ON 8 GUAGE WIRE IS OVERKILL. BUT ARE YOU SPEAKING ABOUT RUNNING 1 BATTERY UP FRONT, THEN RUNNING ANOTHER IN THE BACK OF THE CAR. or TWO BATTERY'S SIDE BY SIDE. I ALSO LIKE THE 200 AMP RELAYS BETWEEN BATTERIES. JUST ME, HOPE THAT HELPEDOriginally posted by CAPRICE2LOW@Nov 13 2008, 05:21 PM~12148095
