when i hit the switch the solenoids click but the motor dosent start all 3 pumps quit at once ive got juice ever where but the motors anybody know how to bypass the solenoids to jump start the pumps
have someone hit the switch and take a test light gounded of course and touch the probe to the first noid and see if it light up...if it does then move to the next...thats how you can tell where the problem starts
Bad battery for sure. The bank has no problem triggering the 24 volts to make the solenoids click, but not enough power to turn the motors. I'll call on one monday and let you know.
if you need to by pass the solinoids to raise the car just get some jumper cables and attach the one end to the motor where the power wire goes then, on the batts attach a nut on top of your exsiting nut that hold the powr wire down there should be enough thread to do this.., you do this because when you tap the jumper cable to the batt it will arc and it can melt the post a little, you'd be better to melt a nut then the post,
