I got an 91 S 10 and it has some kind of digital dash in it.Like no speedo cable or anything .Iwant to put new guages in it but cant afford the didgital gauges please help
i just want to be able to buy white face guages non didgital and put em in custom dash........my main prob is the speedo there is no cable at all
like i didnt even see one on the tranny
if some one would help it would be appriated
thanx
my ghetto friend made white face gauges for his grand am out of paper lol. ill get a pic the next time i see it. it looks pretty good.
They make NON DIGITAL spedos that are fed by electric senders.
I use them in street rods. They work fine. Check with you guage
supplier to see what is compatable. Pick up a street rod mag and copy some web addresses and hit them up. The rest is easy. Just replace your senders in the block with the ones that come with your guages.
Your existing senders wont match up wit your new guages.
Your guages will have a sender wire, a wire for the light and a ground
to the case and a hot wire. Light wire goes into harness with rest of dash lights(tie all light wires togrther) Hot goes to supply controled by key, sender wire goes through firewall to motor where ever sender is onblock. Alll grounds tie together and go to good metal ground.
Sound like alot of shit but not hard if you take your time.
Good luck Toby
thanx man i realy thak you thats more than i expected
