Need help on mounting pumps as close as possible
1K views 3 replies 4 participants last post by  Kiloz El Unico
#1 ·
I want to get these in the spare tire well on my car , so i spun the blocks , can new holes be drilled and tapped on the bottom , is there any oil passages i have to worry about , and with the mounting holes already there can one block be drilled completely drilled threw and a bolt ran threw and screw into the other block , kinda need them touching if possable to get them as compact as possible , dumps will be on the out side of each pump
2024310
2024311
#2 ·
View attachment 2024310 View attachment 2024311
So you just want to make the holes larger to accept a larger bolt?
#3 ·
Even if you were able to bolt them to one another, what would be mounting them to your trunk floor?
I understand what you're wanting to do...
You want the pumps mounted sideways with the ports facing either side... -instead of bolting them together, you might be able to drill the part of the blocks that now faces your trunk floor and bolt them down that way...
#4 ·
Im sure Hoppos can mill something up that has ports on each side.
