1. if i put air compressor in trunk, will it suck all the air from the trunk, and then there no air to compress anymore?
2. if so, can I put nitrogen tank in trunk also, and open it, to replace air in trunk?
3. how do I wire a nitrogen tank to be open?
4. do I use a butt connector on the battery, and one on the nitrogen tank, and then extend it using 18 gauge wire?
5. what color wire works best for nitrogen tank?
6. what color wire works best for compressor
7. can I cut a hole in the trunk to air get in there?
8. Joe, post a pic of your nitrogen tank wire.
9. can I use exhaust from muffler to put it in the tank, see because then I would not need compressor or nitrogen to fill up then the tanktank. see how smart I am!
10. Bigdan said to go blow myself. What valves and wires would let me do this?
11. can I tie the nitrogen tank to the trunk with rope?
12. will knots in the rope be strong enough??
13. what size rope is best to use in air ride Camry?
14. can I use garden hose instead of other hose like what airbagit.com sells?
Come on guys, help me out.
