Originally posted by stevie d@Dec 7 2003, 05:38 PM
1" should be enough
18'' STROKES ARE BIG!!!!AND WITH THAT MUCH COIL ,THE CAR DOESN'T LAY REAL LOW......1'' EXTENSION WOULD BE GOOD FOR
A 12'' OR 14 JUST BY ITSELF....''
I SUGGEST TO DROP THE UPPER TRAINING ARM MOUNTS DOWN,
AT LEAST 3 1/2 OR 4 INCHES,AND STILL EXTEND...........................
THIS WILL GIVE PROPER DRIVELINE ANGLE THROUGH ABOUT 16'' OF LIFT.....THE DRIVELINE MIGHT HAVE TO BE SHORTENED 1''AND,ADD A 700R4 SLIP YOKE TO GET THE FULL 18'' OF LIFT....
NOTE:700R4 SLIP IS 1.250'' LONGER THEN THE STOCK METRIC 200 OR 200R TRANS SLIP YOKE........BUT WITH THE LONGER SLIP YOU'LL LOSE THE SPEEDOMETER DRIVE GEAR......
I'M WORKING ON A 22'' TRAVEL SET-UP RITE NOW ...I'LL SOME NEW PICS TONITE :biggrin:
