1 - 20 of 30 Posts
i am finally thinking about switchin up the monte. i used to drive the thing so much that i didnt want it to turn it into "another bouncy rider" so i just had it dropped wth 14's on it, even tho i love my 13's to death. the problem is that now my audio takes up alot of space in my trunk. i dont need it fancy, just want it quick and to look good when i pop da trunk. i was thinkin about one pump with a marzocci #11 head and 4 dumps with 4 accumilators, six switches (fbss,all down,ridin high) maybe even seven with a side to side switch. id like a streetcharger too but i think it might end up being too much for the cost of one just to keep two optimas topped off.hopefully could do something cheaper. i dont think that i'll need 8" strokes in the back. probably put 6" all around, hopefully that would make it quicker too. i might could put another battery under the hood somewhere too. do you think one of those battery isolator things would work with a 2nd high output alternator just for the switches? also , will 1 pump wit a #11 head be quick at all? is there any other way to make a system quicker without adding another pump? what about going wih hard line until maybe 6" beforethe strokes? are the accumalators gonna slow it down and do they really work as good as shocks? how much will keeping og shocks on slow it?
All I have to say is ditch the stereo and slap a 4 pump setup with 12 batteries in da trunk and some 16 inch strokes out in the rear!
I guarantee you'll be a happy camper! :biggrin: :biggrin: :biggrin:
cant ditch da beats. i spend too much time in my car to not have omething worth listening to.....finally. up until this car, most of my rides have had switches. and even the truck the switches made it hard to have somethin beatin as hard as i like mine. so now i gotta have everything.
anybodygot a #11 pump head 4 sale?
you said that you wanted to run a single pump with 4 dumps? Are you aware that if you run this setup, that you will have to lift the entire car at one time vs. individual corners or sides or f/b?? The dumps would only allow you to dump individual? :cool:
i was told that it coud be done. would i have use a dump block? i am pretty sure you can go front and back with one pump.
Do you mean a dump manifold? I honestly would run 2 pumps though. You can do all the same moves but, you will have to lift the car all the way up at the same time then dump for front or back. Not to mention that when you do raise the car your back will more than likely always raise up first cause its lighter. Just a thought though.
you can get individual lift and dump, but I think you need to run 4 lock valves and a single dump... ...basically you just lock out the cyl's you dont want to move...
as for acc's making it slow, why dont you put a lock valve where you tee the acc's into the lines, then you can turn them off when you want to clown... ...makes it much faster and more violent stop/start
you can hook-up 1 pump, but 2 pumps would be cheaper and easier if you can make them fit... ...play around with the mountings a little and see what you can come up with
b :)
i had to take my amp rack from the trunk to come up wit the space for one pump and two bateries, there is nothing left in trunk space to grab. box and spare take up the rest, i ill never roll without a spare again. i thougt about a continental kit for my spare, but it just woudnt look right on a 80 monte. it aint a cadillac, but so far i have come damn close.the amp relocating came out for the btter. i put them behind plexiglass in the sides in back where the arm rests used to be uner the window , an put blue neons too. wish i could find baby blu plexiglass or tint.
n e way, the only way i might could pull off two pumps is to have a different kinda pump whre i can jst have the pump part in th trunk and mybe have a reservoir under the hood hardlined in. i saw a pump that had a separate tank in a old lowrider mag but i think it was fom a plane or something.
i only have room behind my spare where the jack used to go.
Ummmmm
You can't really "clown" with a one pump setup. :uh:
Get creative!!!
You can mount pumps under the hood!
really and truthfully, when i figured out tht i didnt have alot of room, and seeing that i dont clown too much i was really juust wantng to figure out how to make a bad ass 1 pump set-up. since no one else has done it. and i think that once i have built it nd they see that it works, they might give me props or want to do it themselves. like my homie with a tiny mr2. theres not muchroom except for te one pump in his car, but he would love it if it was a fast 1 pump setup with enough moves to fool most into "knowing that guy has a 2 pump set-up" whn it really is one
there is way to have all the moves an speed of two and size of one pump,help from somma you guys, it'l get figured out and done to my car.
I cut out my spare tire well the same way, but there is no pump there just clean welds and metal!! ;)
Discussion Starter · #20 ·
but that pump is mounted where his spare used to be. i still want my spare to lay there in the hole in da trunk. i thought about that before. even toht about cuttingthe gas tank down to make enuff room for the other pump. but ten that is ridiculous. 10 bucks to fill it before i go to work every morning. wth 13's to, my gas mileage would be like shit.
1 - 20 of 30 Posts
