1 - 11 of 11 Posts
IN THE REAR WHERE THE SPRINGS SEAT IN
I AINT GOT PICS YET TOMOROW ILL TAKE EM
ITS A 88 CAPRICE.I LIFT THE BODY A BIT N DO SOME WRAPING BUT I DONT REALY GET WHAT DO DO WITH IT
IT WONT BE FULL WRAP ONLY REAR ARCES, FRONTS, N CROSSMEMBER
Plate all the sides that you can to along with rewelding the factory welds. Add a couple of gussets and you should be good to go.
SO BASICLY WRAP WHERE THE SPRING SEAT AT, ICANT REMEMBER HOW YOU GUYS CALL IT.JUST LIKEALL THE FRAME FROM UPER SIDE N THE BELOW OR SHOULD I WELD A DONUT BELOW?
IF I WELD ON THE UPER SIDE WONT IT GET IN THE WAY WHEN PUTIN THE BODY ON AGAIN,IM TALKIN BOUT CLEARENS????
You shouldn't have a problem unless your perches are bent already(most cars). You can weld a donut on the bottom or top but, i would run a pipe a llittle larger than the cylinder to allow movement for three wheeling or if you have a high lift in the rear. The pipe will help keep the coil in place eliminating the need for a top cup.
1/4" is fine.
1/4" is fine.
Hey fucker did you ever get your ride going?
1/4" is fine.
OK SO I NEVER SAYID BUT ITS GOIN 12" IN BACK COIL OVER
SO I DONT REALY GET THE PIPE DEAL BUT IF YOU SAY JUST WELD SOME ON IT MAKE A 2" HOLE FOR CYLIS N A DONUT TO THE BOTTOM SO IT WILL BE STRONG ENUFF SO COOL
1 - 11 of 11 Posts
