1 - 10 of 10 Posts
i got one knock off that both ears are broke off how the fuck do you get it off so i can take my wheels off? any suggestions? if a pic is needed i can get that too
try getting it stuck with diamond shaped adapter sorry lol i dont know the name.. the thing u put on diamond shape knock offs with.. that has 2 ears to it.. but sorry to see that bro that sucks must be a fake china cheap shit and ghetto shit that broke.. but try what i told u it should work if u get that stuck in a right position
I helped my homie wit that same prob'... we had to weld a piece of metal to where one of the ears was and used a pry-bar to twist it off.
if that dont work... your gona have ta cut it off.
good luck...
good luck...
it should work! if welded strong!
i had the same prob with a set of LA wire 2 bars years ago, as already said, i used a big pipe wrench to get it off, no problem.
i had that smae problem a while back, i posted a topic about it, i had to girnd into it because i couldnt get a pipe wrench to fit in there, with the deep dish rims the pipe wrench wouldnt fit.....what i did was grind slots into the knockoff, as you do that you will eventually grind into the adapter too, just be careful not to hit the rim, then i just took a big pice of flat metal and used it as a chisel and punded it until it started coming off, remember the anti-seize next time...
1 - 10 of 10 Posts
