1 - 5 of 5 Posts
trying to install driver side window
i think that one rivets into place, but it may bolt in. im assuming your talking about the door glass and not the stationary quarter glass...right? since there is no frame around the glass edge, there are many adjustments to the glass, hence the brackets and hardware attached to it. my advice is to take things apart slowly and make sure you start and finish the job all at once. dont take it apart and leave it or you will forget where it all goes. it isnt very difficult but if you dont understand everything in there, maybe take it to a glass shop, usually if you have the window and all the old glass is cleaned up, they will cut you a deal. I work for auto glass specialists/safelite autoglass up here and we do it all the time. be sure to mention it to them that the old glass is vacuumed up and that you have the new one. post here if you have questions. pics will help...
it bolts in place, taking the door panel off correctly and reinstalling it correctly takes more time than actually changing the window
1 - 5 of 5 Posts
