1 - 9 of 9 Posts
for some reason when i dump the front the driver side goes lower than the passenger side, its an uneven dump
ive seen some setups that have 2 slowdown valves 1 pump. assuming u dont have that. then you could have a spring worn out more than the other. or the spring is cut shorter than the other
i dont think it would be the srpings because i have had this set up for 2 years now. recentely my batteries died completely and when i charged them and tried hitting the switches the front would drop unequaly....
is it dropin uneven or is it settin uneven ????
it's your spring or you have bent something that could also
do you have a sway bar ??? check that shit it may have broke and now it's actin differn't seen that a few times
ok thanks, i just dont know how i would of bent something becasue before my batteries died everything worked fine....:S
1 - 9 of 9 Posts
