1 - 8 of 8 Posts
Just make a cable long enough to connect the last negative in the left bank to the first positive in the second bank. Then connect positive from battery charger to first prositive on left bank and negative from battery charger to last negative on right bank. Remember to disconnect your quick disconnect.
Hi I have 2pump setup 36v by pump and a have a schumacher se-1072 charger I wanna know how i have to plug it to charg my 6 batt simultaneously
:thumbsup::thumbsup::thumbsup:CCE HOMIE NICE!!!! good da you know now how 2 do it :thumbsup:
Just make a cable long enough to connect the last negative in the left bank to the first positive in the second bank. Then connect positive from battery charger to first prositive on left bank and negative from battery charger to last negative on left bank. Remember to disconnect your quick disconnect.
n also remember da 10amps charge faster but not da strong n 5 amps is slow but strong :thumbsup:
1 - 8 of 8 Posts
