i just put a new pump head on and now car wont lift......it raised and lowered it 2 times and now wont lift.....it tries to lift but it wont........any one have an idea of what could be wrong
FIRST CHECK THE DUMP.....TIGHTEN THE SLO-DOWN ALL THE WAY IN , AND HIT THE SWITCH.....IF IT GOES UP.....BAD DUMP......IF THE SAME PROBLEM...MOST LIKELY THE PUMP TO BLOCK SEAL....THIS MOSTLY HAPPENS WHEN A MARZOCCHI IS ONLY 2 BOLTED TO A BLOCK....AND THEY SHOULD BE 4 BOLTED.....AND TORQUED TO 25 FT. LBS. :biggrin:
