Originally posted by squeege40@Dec 5 2003, 05:06 AM
the truck doesn't lay but i had an 83 with the blocks in the rear and it would still lift and ya i got the tank clear full of oil
O.K...HOW HIGH IS THE TRUCK LAID OUT..STOCK HIEGHT???..IS ALL THIS NEW EQUIPMENT??? AND IF IT HAS BLOCKS ,NORMALLY IT'LL LIFT 8'' OR SO, NOT 12''... OR 3 TO 4'' OVER STOCK ,DOES IT STILL HAVE SHOCKS...SOME OF THE S-10 WOULD BOLT THE SHOCK TO THE 'U'BOLT PLATE AND,WITH THE BLOCK IT WILL MAKE YOU LOSE THAT DISTANCE OFF LIFT???..I'VE SEEN PEOPLE BEND THE FRAME TRYIN TO OVER LOCK IT UP.....THE SHOCKS WOULD LET IT LIFT TO A CERTAIN POINT,AND STOP,BUT THE CYLINDER WOULD KEEP GOING A BEND THE FRAME
JUST GOT TO GET ALL THE INFO I CAN TO HELP YOU...DON'T WANT TO SOUND STUPID....I HAD USED SOME OLD LUXOR STROKES ON A CAR AND,THE GUIDE SLEEVE HAD GOTTIN JAMBED,THE SHIT WOULD ONLY LIFT 4'' TOOK A WHILE TO FIND IT OUT????? HOPE THIS WILL HELP :biggrin:
