I just bought a two pump set-up for my 1986 Buick Regal. I'mm gonna re-enforce the frame eventually. Right now i just want to partially re-enforce it so i can get my hydro's in it. You got any suggestions? Like what i should do? What i should focus on? The stress points?
you don't hafta reinforce it to install your hydros. but if you want some ideas on the easier things to reinforce.
rear frame(tirewell back)
buy "unbreakable" ball joints
reinforce "belly"(front crossmember)
well there's a start. ;)
you wnt need to reinforce anything, to install your dros
inless, you hop, 3 wheel, or run a high voltage set-up, like 10 batts to the nose or what not ;)
Ay thanks to all for the info
