1 - 16 of 16 Posts
:uh:
I have a 4 pump 12 batt setup one of my pumps is not working right. When you hit the switch up the pump lifts the corner but much slower then the other 3 pumps the motor is good and i took apart the pump head and its fine and the batts are all charged please help me.
Originally posted by veto213@Jan 7 2004, 11:57 PM
check ya dump
yea, check your dump or you'll have to call someone to drive about 30 min just to tell you your dump is bad....ain't that right mitch! :uh:
Originally posted by stankin85+Jan 8 2004, 04:58 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (stankin85 @ Jan 8 2004, 04:58 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--veto213@Jan 7 2004, 11:57 PM
check ya dump
:biggrin:[/b][/quote]
59 imp 64 imp 77 mc
also, check the O-ring between the block and the pump head. My homies did the same thing and that was the problem.
Originally posted by vegashopper+Jan 8 2004, 01:52 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (vegashopper @ Jan 8 2004, 01:52 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--EDDIEA408@Jan 8 2004, 01:38 AM
CHECK YOUR DUMP IT ISN'T RELEASE ENOUGH AIR
huh????? :confused: :confused: :confused: :dunno: :dunno:[/b][/quote]
newbie i guess that explains it ;)
i honestly would say that it probably isn't your dump... If the car doesn't fall back down, then that's not the problem... check the o-ring between the pumphead and block... if there's nothing wrong with the pumphead or motor, I'd say that seal is probably the problem. Also make sure that your pumphead is torqued correctly.
Discussion Starter #14
Well I fixed the problem thanks to JUICEDKID. It was the bolts that hold the pump head together they were loose.
GOOD LOOKING JUICEDKID ;)
Originally posted by Bagged_Conti@Jan 23 2004, 09:37 PM
Wow, I may be incorrect here but that loo0ks an awful lot like the person asking for help and the person that helped him are "magically" the same person.
I know. He showed me this post after trying to charge me to fix my pump. I didn't know that he gave himself advice. :uh:
1 - 16 of 16 Posts
