1 - 10 of 10 Posts
sup LIL
i got a 81 parisienne brougham coupe i was originally gonna go with hydros but the roads in montreal are bad and im looking for a more comfy ride if anything...
im only looking to lay and play but with a good speed... not hydro fast and not too slow...
i was wondering what type of setup would be best
thx
Joe has the answer. you'll see. He knows stuff about air suspension.
sup LIL
ok, Im going to call it....."You gots to start somewhere kit"
$789 with Free shipping to the US states only. For my friends here at lay it low!
will include
4 x Dominator 2500 or 2600's your choice.
1 x 5 gallon Black 1/2" ported Tank
1 x Viair 280c Compressor
1/4" Water Trap
4 x SMC 3/8" Valves
1/8" Airline for gauges
3/8" Airline for bags
1 x Dual Needle Gauge (Black or White face)
110-145 PSI Pressure Switch
1 Relay with Harness
2 x Toggle or Rocker Switches, your choice
Fitting Pack
I do recommend upgrading to a Viair 400c (xtra $50) well worth it.
This little kit is a Front Back Set up! Its complete and will come with everything except power wire, and a fuse holder, you will need brackets. We have most popular applications available. I also am willing to make any changes you require.
The only thing I would ask Keven, is to up it to 1/2'' everything,fittings,pipe,and if you want a lil play go with 2, 480 comps,with 4 more 1/2'' valves You can always add to your setup later:thumbsup:
thx joe... air assisted is perfect there just next door... i know i wont have any probs with that... but when you say go with 1/2 everything... you mean for valve, bags but what about the gauges do i need 1/2 also or can i get electronic... i dont want any gauges on my dash rather have the little led display.. and where does the psi switch connect to...
im a real rookie to bags
sorry no you don't need 1/2'' air line for gauges,just let KeVin know what you want .The psi switch gose to your relay,to tell the comp to go on,and off.
When i wired mine up i added a toggle between pin 86 an the pressure switch or maybe it was between 12volt source an pressure switch.Either way works
what about reinforcements... i know i gotta notch the front top spring pockets... can i keep my stock arms... and for the back do i need anything done around the spring perches
1 - 10 of 10 Posts
