1 - 18 of 18 Posts
hey guys im new on the sceen with a lot to learn y 1st question is i just picked up a 64 with 2 pumps and only 4 switchs it basically just does front and back can i buy a box and will it give me mor choices when i hook it up side to side maybe 3 wheel the pumps are black magic's i will post pics later ...
Adding the a 10 switch box will give you Front, Back Left side, Right Side, Pancake, all four corners, and a see saw front to back. Just remember with two pumps you can not lift a individual corner up when it is dumped. Hope that helps a bit.
Originally posted by sixt4 low low@Dec 7 2008, 05:31 PM~12361574
how do i post pics ?
click "Add Reply"
then when tha page loads click
then browse yr comp and find the pic and then click "Open"
then
click this code and it will turn black, then right click w/ mouse and select "Copy"
go back to this page, and right click w/ yr mouse again and select "Past"
thats about good as i can explain it homie. :biggrin:
looks very good , not a bad price at all far as tha pic's shows. :thumbsup: :worship: :eek: :puffin:
Originally posted by dtysthriderz@Dec 7 2008, 11:48 AM~12359815
yep post pic's , 4 switch's .... then it does more than f/b
your right got side to side after a full charge today :biggrin:
yep thanks i have a lot too learn
Discussion Starter · #13 ·
Originally posted by MoreBounce 805@Dec 7 2008, 07:41 PM~12362994
:thumbsup: Very nice Box!  ;)
yes its descent needs some love the guy who put the bumpers and body panels on was an animal nothing is shimmed right as you can see the rear dside bumper needs to be lifted and leveled out ill get it tight after the weather brakes one thing i need to do is and if you have any info help i need to replace the seals in 1 front and 1 rear cylinder they are leaking .....
Its a pretty simple procedure. Just holler at me when you get ready to do it and ill walk you through it. ;)
Discussion Starter · #15 ·
thanks ill do that
1 - 18 of 18 Posts
