1 - 5 of 5 Posts
hey, i am thinkin of gettin nitrogen and i was wondering how i got to do all the plumbin so i can have the air and the nitro.......and how would i switch from the nitrogen to air or vise versa.
and what are the risks of using nitorgen
Face Puncher
the easiest way is to just plumb the line into the tank like it was an air compressor. set the regulator to the desired pressure, and open the valve when you want to run the nitro..
you could get all fancy and use a little 12V valve to turn the bottle on and off, but then you would need to leave the bollte on all the time..
risks...
big ass tank under tremendous pressure in the trunk of your car, not good if you wreck.
make sure it is mounted super securely.
use a pop off valve in case the regulator fails, dont want the tank to rupture..
thats about it for the risks..
1 - 5 of 5 Posts
