1 - 10 of 10 Posts
What type of regulator do you guys use for your nitrogen tanks to charge your piston pumps. I need one that goes to 160 to 200
Where can i get a regulator that goes to 200 for my nitrogen tank wondering where if i could find one on e bay but i need to know what to look for
You dont need one bro, hook up your gas line to the valve on the piston tank.........and ''crack'' the valve on the nitrogen bottle a little at a time till you get the desired pressure. Use a guage on the oil side(filler port) so you will know when its charged all the way.
yeah you can do it like that and make yourself a high pressure 'tire guage' for less than 10 bucks, if you wanna live dangerous,lol
Our Crown order pickers use a bladder accumulator for the lift system and the charging kit directions are the same......but then again I am a certified technician sooooooo.............PLEASE BE CAREFULL!
Thanks Andrew now I can sleep better :biggrin:
found a nitrogen regulator good up to 400 on ebay i think this will work its used for hvac testing.
Originally posted by baggedout81@Jan 24 2010, 10:32 AM~16393994
Look for this one if you can
Harris
Model No. 25-500
xs 2 got one, its the most accurate
1 - 10 of 10 Posts
