1 - 20 of 28 Posts
ok so i was bumpin and then all of a sudden the music is off and now it wont rn back on i did every thing fuse, wiring everythin right i even hooked a tweeter str8 to the deck wires and still nothing no reset button either wat could it be
and juan if ur reading this you can have ur deck back now :roflmao: :roflmao:
dont get butt hurt
dont get butt hurt
pioneer makes some of the best decks out i had one almost 9 years and it still plays like brand new i would take it to your local car audio shop they should fine the source of the problem :cool:
did you check the fuses on the back of your deck and the car fuses? do you have a wire harness and if you do see if its a tight connection with your factory insert plug. check the wires that go into the back of your deck if your ground is loose or if your power is loose you might need to try to tape it down all the way back in there.
Originally posted by ILUVMY82@Dec 30 2008, 11:18 PM~12562995
nothings loose just stopped working
how long have u had it?
i would say the fuse for the head unit but you say that not it so bets the hell out of me but i been running pioneer for almost 10 years and never had this problem
the only thing i can think of doing is getting a dirt cheap deck from some store and then putting it in. if it works then its the deck thats broke if it doesnt turn on then its the wiring.
· THE ENTREPRENEUR
The pioneer decks are infamous for the sub output r c a on the rear to go out, if your speakers were running off of the amps that explains that problem otherwise id say pull the deck out and hook up a speaker to each channel and see if you get anything out of it.
1 - 20 of 28 Posts
