1 - 9 of 9 Posts
G
ok my friend has two pioneer 12s and a volfenhag 1600 watt amp everything was working good with 8 gauge wire then he wanted to upgrade to 4 gauge wire now he has a noise in the subs like extra bass notes the hit by there self and shit ive tried everything to fix it ive regrounded it ran new rcas i put his shit in my car and it works fine i also have 4 gauge i cant figure it out any suggestions will help :angry: :uh:
kinda wierd sounding....maybe cut the gain down a little...are the power wires running down the same side as the rca's?..
2GUNZ
:dunno:
Never knew upgrading to heavier gauge would do that. Try running the 8 guage again. Then if the problem goes away, run the 4 guage outside the vehicle, if you got enough wire, if the noice goes away you got interference, if it stays it is something else.
TURN THE VOLUME DOWN ALL THE WAY...IF U HEAR A NOISE ITS DISTORTION... ULL HAVE TO RUN UR WIRES A DIFFERENT ROUTE AND THAT SHOULD FIX IT IF THATS THE PROBLEM.
Originally posted by sabre@Sep 22 2003, 02:18 AM
could the larger wire posibly cause more voltage drop and create a bigger gound loop .. ??????
did you upgrade the -negative side of the power .. ??? :dunno:
Thats a good point he's making...did you upgrade you're ground ??
Also one more thing what radio are you using ???
If it's a factory radio and you're using a Hi to Low converter that might be giving you problems as well.
I will ask this question again...are you running the rca's next to the power wire...if so that could be giving you your problem
1 - 9 of 9 Posts
