1 - 9 of 9 Posts
*** WTF !! I was looking under my 64 when I had it booted up & i discovered that the slip unit that I had installed wasnt short enuff & it pushes my driveshaft up & "Eggs" out the "REINFORCED" aftermarket carrier bearing I paid $80 for ....
YOu can clearly see that the slip is not short enuff ... Anyone know exactly how much of a slip unit should be installed ??/ I believe a 3" unit was put on...... Would a 5" best suit my needs ?-- You can see that there is more room for movement & I am thinking about installing another slip unit at the Weld yolk end ........ Would this work fine or would i have to buy a whole new / longer slip then the one I have in there?????
Badass, & impalas631 -- If you could help it would be appreciated .. Thanks, BOB_T
this is the end where i think i will install another slip unit in .... Right off the "Weld Yolk" ........ In this pic the cylinders are NOT installed correctly & are just sitting in them pockets.... They have rod ends in them now & actually make the car raise up about 4" higher...... Thanks again, BOB_T
*** Shit -- No pic.....
Originally posted by T BONE@Dec 17 2003, 01:55 PM
TTT for cheddar bob, since you live in wisconsin now.
:roflmao:
TO THE TOP
Originally posted by dabomb@Dec 17 2003, 01:10 PM
career bering 80$...wtf...payed mine 36$ Canadian at a local drive shaft shop
his carrier is an aftermarket unit as he clearly states :0
1 - 9 of 9 Posts
