i have the following setup in a 99 Grand Prix but it doesnt sound like i want it to,the radios max volume is 30 and when i have it at 15 and adjust the gain on the amp (speakers unbridged),i have to turn up the gain almost all the way(if it were from 1-10 it would be at 9)so i decided to bridge the speakers and i was only able to turn the gain down to about 7.I dint want to bridge it cause i like to have left and right balance,on all the other systems ive installed ive been able to turn the radio halfway and the amp halfway.dont get me wrong,it sounds good but i was just wondering if i should wire thespeakers differently to change the ohm's,or shold i just get a bigger amp like the
Kicker ZX650.4
» 4-channel car amplifier
» 120 watts RMS x 4 at 4 ohms (170 watts RMS x 4 at 2 ohms)
» 325 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
» variable high- and low-pass filters (50-200 Hz, 12 dB per octave)
» variable bass boost (0-18 dB at 40 Hz)
JVC KD-HDR1
20 watts RMS/50 peak x 4 channels,
Profile AP1040 4-channel car amplifier
» 80 watts RMS x 4 at 4 ohms
» 125 watts RMS x 4 at 2 ohms
» 225 watts RMS x 2 bridged output at 4 ohms
» 4-ohm stable in bridged mode,
Infinity Kappa 693.7i 6"x9" 3-way car speakers
» 2-ohm impedance(top of box says 4 ohm as well)
» power range: 2-110 watts RMS (330 watts peak power)
» frequency response: 35-25,000 Hz
» sensitivity: 95 dB
Polk Audio db5250 5-1/4" component speaker system
» 2-way crossover network (4,000 Hz, 12 dB/octave)
» frequency response: 53-25,000 Hz
» recommended power range: 10-100 watts RMS
» peak power handling: 200 watts
» sensitivity: 89 dB
» Impedance:4 ohms
Kicker CK44 4 Gauge 4Ch Amplifier Kit and Speaker Cable
I have a system for sale that you wont be upset with!
Kicker L7 and Memphis st1500d! ;)
Originally posted by Sporty@Sep 16 2007, 09:05 PM~8803983
i didnt think he was talking about subs being that he only mentioned 6x9's and 5.25's and 4-channel amp...
ah, good point.
I dunno what it's not doing that he wants it to do then. Not loud enough? Muddy sound?
