1 - 5 of 5 Posts
there is a seal that goes around the shaft of the pump head and sits inside the block. it is leaking. there are two different types------a metal one with o-rings which are very easy to replace, and the old school round piece of rubber with a very small spring inside surronding the hole the pump head input shaft goes through, <---------bad description
i perfer the old school kind but you will probably have to go to a hydraulic shop to get a replacement.
1 - 5 of 5 Posts
