21 - 23 of 23 Posts
i always thought the oil did return foamy mine does i thougfht it was normal
Originally posted by Joost....@Nov 5 2003, 02:44 PM
because of the pressure air and oli is mixed, that whats causing the foam, raise the car like an inch, and slowely loosen the fittings on the cilinders, the car will drop a little bit, quickly tighten them, after that it will foam less. a little bit of foam is normal
wut u i do is lock up the car then lossen the fitting on the piston till all the bubbles are out then tightn it ....u sould be fine ..... exactly wut joost said ................
BLEED YOUR LINES!!!!
after it starts to run straight with no bubbles, add more fluid and repete. ;)
21 - 23 of 23 Posts
