1 - 19 of 19 Posts
i just finished my frame,fully boxed and now working on the rear end.anyways after junking 4 cars be4 this 1 now with the backbone strong and ready 2 go i want 2 make a set up that going 2 make the slackers cry.this is what i have in mind and what i want 2 do ok here goes.8s in the front 14 in the rear overcoil of coarse.4 pumps.i want 2 run 2 seven or 8 battery bays what kind of motors and gears do u think can handle or at least give me the best life out of them 4 a every weekend ass kicking ride.what do u guys think ?
buy a set of spares runnin that kind of volts. I would. Ive had motors last for years running 48 volts with #9 gears . dont get serious air or anything but i get some serious clownin in.... Heres a secret i run a homemade charging system that maintains the battery voltage , always having my battery's charged up full all the time . the setups last longer . less fatigue.
hmmm homemade charging system very interesting
plans for sale? :biggrin:
I run seven to both of my front pumps they last for while depends on how much you hop.thats my in my avy :cool: good luck dont know of that many hoppers in Burque.... thats my home town :biggrin:
There free LOL. Ill draw up a simple diagram tomorow ;)
thats cool man thank you
Originally posted by 84lowcutty@Aug 4 2005, 09:13 PM~3543912
thats true.juice here is a joke.i want 2 put a car on the streets that yanks.im looking 4 more of a dancer then a hopper but what do u think about the gears and the motor?
HOPE YOU WRAPPED YOUR FRAME GOOD :scrutinize:
ttt
I cant draw for shit either
Nasty, you just have like 4 trickle chargers plugged into a 110v power inverter, and each charger's hooked up to one batt while they're all connected @ 48V? How long have you been running that setup?
ps power wires don't go to the tanks. :cheesy:
also, how does it NOT over charge the setup> wouldnt it be easier to do a street charger?
Like i said i cant draw.. power to the tank lol.. mine was setup with automatic chargers 6 amp or 2 amp each. It works series parallel because there is 4 seperate chargers. the charger sees the battery as a 12 volt battery this way. I was able to run the pumps the same time as the chargers but sometimes they would clip. ( protection) so what i did was just hooked up some relays that would kill the power to the inverter when either pump was powered up. i just did this setup because i had the 4 chargers already.. someone who has a multi charger could benifit hookin it up the same way. Auto chargers will maintain tha batterys without over charging... the street chargers would be the way to go though for a new system. but check this i use the starting batterys insted of deep cycles.. more cca's more POWER LOL... trust me it is better than hookin it up to the alternator. this setup will instantly have the battery's beck up in just minutes! think about it if you hop the shit out of it, the chargers will start at 6 amps each battery (24 amps total) will charge them up very quickly , tapering off to a 2 amp charge to top off the battery's then standby LOL .. No secrets here it works!
I guess it would/ i never owned one so i cant say how good they work --- I hear from owners of them that they are very happy.
1 - 19 of 19 Posts
