1 - 16 of 16 Posts
Bellin'
Discussion Starter #1 (Edited)
SOLD
I took this out when parting out audio. Worked great, sounded great. This things heavy so shipping large part of price. I will give warranty of 7 days after item is shipped so you have assurance it works. If any issues, may be returned at buyers shipping cost for full refund.
Description:
Picasso amplifiers exude Performance and Quality with 2.5 to 1 power supply ratios and superior damping factors for excellent woofer control under high-stress applications. With both class "A/B" and class "D" amplifiers to fit any application, Picasso is the answer to loud and clear sound reproduction.
Features
  • Fully regulated MOSFET power supplies
  • PWM circuitry
  • Tri-guard amplifier protection
  • IDI™ (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
  • Line Outputs
  • Bi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)
  • Continuously variable high and low-pass crossovers
  • Variable subwoofer equalizer
  • Phase inversion switch (0 - 180º)
  • OEM floating ground input
  • Platinum 4-gauge power connectors
  • Tri-mode operation
Specs
  • 2-channels
  • 160x2 watts RMS @ 4ohms
  • 260x2 watts RMS @ 2ohms
  • 520x1 watts RMS @ 4ohms bridged/mono
  • T.H.D.: 0.02%
  • Freq. Response: 10Hz-30kHz
  • S/N Ratio: Greater than 97dB
  • Damping Factor: Greater than 200
  • Input Sensitivity: 0.2-6.0V
  • High-Pass Crossover Freq: 50-600Hz
  • Low-Pass Crossover Freq: 50-150Hz
  • Subwoofer EQ: 0-18dB
  • Subwoofer EQ Freq.: 40-120Hz
  • Dimensions (Inches): 11 x 2.5 x 18.5
hey johny its iain in sydney bro i didnt look at the profile so you got a new car bro i saw your old six for on ebay work out a price and i can pay pal you for the amp
cheers
Hi johny the payment on pay pal has gone through please let me know if it is all ok thank you ,The address came up as kevin somthing i hope this is you . i just copied the address you provided . i deposited 150.00 :thumbsup:
1 - 16 of 16 Posts
