Setting up a data base for all PESCO power packs. Also a database for pump heads and motors that can be matched.
The following information is needed:
MODEL # (if power packs, provide specs for gears and motor)
HP
RPM
VOLTS
AMPS,
DUTY CYCLE
GPM
WEIGHT
GEAR TYPE
SPEC#
ORDER #
Those that provide information will be given a copy of the data base.
You give me the specs for a pumps/motors/power packs, that you currently use on your ride, I send you the entire list.
You send a scan or copies of an PESCO manual, you get the list.
This information will not be put on the Internet at this time.
I already have 22 items listed. I must be able to verify the info you send. A PIC, scan or photo copy of the tag, or a scan of the book or manual you are using.
Do not post your info here in the forum, unless it is already posted elsewhere.
REGARDING Ebay and model #,
I already have many specs numbers, I can only accept numbers that are not already in the database.
email me or PM
[email protected]
I first started using PESCOs in the 70's. If you need proof I already have specs, let me know. If you want the list, you gotta put in.
HP
RPM
VOLTS
AMPS,
DUTY CYCLE
GPM
WEIGHT
GEAR TYPE
SPEC#
ORDER #
email me or PM
[email protected]
