1 - 5 of 5 Posts
i've done a little research and this is basically what im goin to start buying piece by piece so what i need from you guys is to basically let me know if i've made a bad desicision or theres a better product out there here goes the list
1. 12-GALLON AIR TANK x2
2. 1 York 210 compressor
3. Coalescing air filter
4. 8 GC 1/2" EXTREME VALVES 450 PSI
5. 10 SWITCH BOX
6. adj PRESSURE SWITCH 200 PSI
7. Dakota digital 5 way gauge & senders
8. AIRLIFT EXTREME GEN 2 BAGS 300 PSI
9. Full-size Chevy Front Bag Mounts
10. Axle Bracket with Shock Mounts
11. 5/8” DOT Reinforced Airline (50' Roll)
12. ½” DOT Reinforced Airline (50' Roll)
13. York Compressor Mounting Setup for SBC
14. fittings?
would i need a second compressor in my trunk like a vair or similar
You'll need fittings, they are all different depending on you config, but some are standard. Go to www.fittingsandadapters.com.
And why the 1/2" line, if you run straight 5/8 all the way from tank to bags, you'll get true 1/2" system. just FYI. It looks like you went through Suicidedoors.com, good stuff, just get another filter for that York.
Ask Jason about the exteme 1/2 kit, and swap out what ever you want and he'll hook it all up. allot of the parts you have there are in it already.
a hydraulic or steel braided line at least 18" long to come from the york. Its a heat issue. I've got a hydraulic line from the york to the tank. works great but I don't play as hard as Moco ;)
1 - 5 of 5 Posts
