1 - 10 of 10 Posts
I'm trying to find out if my 72 Riviera has a piston pump on front. It is a black CCE pump with a pressure gauge. Also what would cause my front to leak down completely after being locked up for around 2 hours? Thanks
Leaky dumps or check valve can allow fluid to push back into the tank causing it to dump the front. This is assuming there is no visible oil leaking from a seal somewhere.
I love hearing "PAPA"
How high is the PSI readings on the pressure gauge if on the air side?
1 - 10 of 10 Posts
About this Discussion
6 Participants
Hydros
LayItLow.com Lowrider Forums
Full Forum Listing
