On an adex dump, you got the return, the pressure and the break, do you use the 3 of them? Thanks...
I got single gate for one adex...Originally posted by mean3wheel_lean@Aug 17 2005, 08:36 PM~3645295
how many pumps you runnin per adex
I know. I just got goose bumps.....Weird huh?Originally posted by CrystalCutlass@Aug 20 2005, 09:00 AM~3661508
Everytime I see that setup, I just go 'WOW'!
Originally posted by blueouija@Aug 18 2005, 01:01 PM~3649497
the only time I'd use all all three ports is when hooking up aircraft pumps to an Adex dump....
since your using it on a gate pump, block the pressure port with a plug... just like 216 said... Return goes back to the resivoir and brake goes to the cylinders off of a T-fitting.... if you have room put a big parker slowdown between the t-fitting and the brake port of the dump... I just didn't have the trunk space...
