Call the people were you go your accumulators they should have all the fittings you need. :cheesy:Originally posted by lyinlow@Nov 15 2003, 09:23 PM
ok if its the orb do they make a orb to pipe thread fitting??
cuz i had a orb fitting and it wouldnt thread into the t i have
hmmmm
most accumulators that are the bladder style have 'o'' ring boss threads....these are ball style accum..... and most used in automotive hydro's are #6 or #8 'o' ring boss,hope this will helpOriginally posted by 216RIDER@Nov 15 2003, 06:28 PM
I'm not 100 percent sure, but if you're sure its not a pipe thread, then it must be an ORB fitting...
You know that if you put the accumulators and cylinders with no spring is going to be even better ride quality.Originally posted by lyinlow@Nov 16 2003, 11:48 AM
perfect, they are the bladder style so i must need the orb fitting, ill go n get orb fittings tomorrow night! after work! one step closer to tryin it out, now all i need are some 3/4 tons to act as spacers for the rear!
Thanks alot
Trevor
Thats what I m going to do in my cutty I m going to use a pipe as a spacer like that you can get a really good ride in the back.Originally posted by lyinlow@Nov 16 2003, 12:26 PM
i was plannin on doin that but i need a spacer inbetween the cylinder collar and my upper mount so that i can get the max lift outta the cylinder, i was thinking a coil would work good, but would a piece of tubing work just the same? i just havent saw many setups with tubing as spacers
Trevor
You are welcome just weld the pipe to the cups just like a coilover.Like that you can remove the cylinders to replace the o-rings.Originally posted by lyinlow@Nov 16 2003, 03:15 PM
cool maybe thats what ill do then instead of coils, seems like i would waste the money on coils if all i was gonna use em for was to be spacers, i could get some pipe for a lot cheaper!! thanks alot!!
Trevor
Just doit like a coilover set up in between the two cups instead of placing a spring weld a pipe same size as the coil. So that replaces the coil so when you need to replace orings is easy.Is basicly a coil over set up with no springs instead a big pipe.Originally posted by lyinlow@Nov 16 2003, 07:56 PM
so yur sayin just put a regular donut on above the collar and weld the pipe to the donut . that way the cylinder and spacer will be separate ?
Trevor
