1 - 8 of 8 Posts
on the side of my pump blocks thier is a a set screw with a spring and bearing in side of it and a bolt with a spring and bearing what are they for and i heard thier is a way to modifie the pump
i was wondering the same.....but i think its just a pressure relief?
You are Correct It is a pressure relief!!! say for instance the pressure relief is set for 1500 PSI (probably not just an example) any time the Pressure reaches 1500 PSI the excess fluid that enters the system is bypassed back into the tank.
Somebody knows how to remove the pressure relief valve and use it as a return port on these pumps.
I remember somebody having pictures of where to drill a hole or something. Post them back up and post the info on doing the mod if anybody has info.
oh yea and why doesnt this damn block have a seal/o-ring between the pumphead and block??
whats the torque specs for the pumphead?
1 - 8 of 8 Posts
