I just want to see which are better and why.
Hey dan why are those the best and were can I get them see I posted the another kind.Originally posted by 216RIDER@Nov 15 2003, 11:06 PM
polypaks are the best.. hands down
So were can I get them. :cheesy:Originally posted by 216RIDER@Nov 15 2003, 11:41 PM
x-rings (or quad rings) are much better than a standard o-ring due to the dual sealing surfaces and the resistance to rolling on itself..
the next better choice would be a u-cup..
but the best choice is a polypak, which is just a u-cup preloaded with an oring..
the o-ring keeps the sealing lip of the polypak pressed tight up against wall of the cylinder, whereas, to some extent, the u-cup relies on pressure to create a seal..
and you can see that the polypak has a sealing surface that is square to the applied force, and an oring has a beveled edge exposed. so the oring has a better chance of being "pushed" back inside of the piston and letting fluid pass by..
polypaks also have a higher pressure handling capability than an oring..
not bad for a bag guy, huh?![]()
Any websites. :cheesy:Originally posted by 216RIDER@Nov 15 2003, 11:45 PM
anyplace that sells industrial hydraulics and seals..
they'll need to know the bore diameter, piston goove height and depth..
Any websites. :cheesy:[/b][/quote]Originally posted by Big Baller 82cutlass+Nov 15 2003, 11:50 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Big Baller 82cutlass @ Nov 15 2003, 11:50 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--216RIDER@Nov 15 2003, 11:45 PM
Hey dan can I get those o-rings at NAPA. :cheesy:[/b][/quote]Originally posted by Big Baller 82cutlass+Nov 16 2003, 12:05 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Big Baller 82cutlass @ Nov 16 2003, 12:05 AM)</td></tr><tr><td id='QUOTE'>Originally posted by -Big Baller [email protected] 15 2003, 11:50 PM
Do you know if NAPA sells them. :cheesy:Originally posted by hoppinhonda@Nov 16 2003, 04:14 PM
CCE cylinders already have them.NOT the red ones,the ones with the turned down tops.![]()
Originally posted by hoppinhonda@Nov 16 2003, 08:37 PM
I doubt it.![]()
