gotta project car and im looking for ideas on how to get the rear locked up as high as possible.. anything from 14 inch cylinders on up..
most commonly thing done is to drop the upper trailing arm mounts either to the frame near where the lowers are mounted or drop the upper trailing arm mounts below the factory locations about 5 inches...will possibly still need to do some driveline work such as a slip yoke or cutting some material off...Originally posted by look_what_i_can_do@Jan 15 2010, 11:16 PM~16306323
The type of car would be usefull here.Originally posted by look_what_i_can_do@Jan 16 2010, 12:16 AM~16306323
are the reverse cups upside down?Originally posted by gottie@Jan 16 2010, 04:21 PM~16311129
:0 :0 :0 SAME THING HERE :0 :0 :0 :0Originally posted by gottie@Jan 16 2010, 04:24 PM~16311144
Too bad they don't lay though.Originally posted by gottie+Jan 16 2010, 06:21 PM~16311129-->![]()
[/b]
<!--QuoteBegin-gottie@Jan 16 2010, 06:24 PM~16311144
no they are doing it because its safer that way!Originally posted by KingsWood@Jan 17 2010, 05:30 PM~16318207
:wow: are they doing that, just for a few extra inches?
i drive mine locked all the way up within a cpl inches 80 on the freway , no swinging going on hereOriginally posted by AndrewH@Jan 17 2010, 06:23 PM~16318607
custom 4 link. learn how to do one to do what you want. push the game, force others to do legit work! dont settle cuz you will want more later, and adding taller cylinder isnt always the answer. I set my rear up for 20" cylinder, then decided I wanted to do 28's,sit a lil lower and lift a lil higher.. but it swings the rear end way to far forward,those few extra inches
caddies are tough tho, you will hit the back bumper goin up, and the front bumper going down!
