1 - 3 of 3 Posts
Don’t you need 2 reverse cups on 1 cylinder? I’m doing a cutlass supreme and been a while since I’ve had hydraulics but I like the idea of that power ball with the spring over the cylinder but looks like I should use 2 reverse cups 1 on bottom of spring and 1 on top no?
you might be thinking of these things they called top hats - which is kinda like a cup for the top, mores so for alignment but if you have a bridge or at least a donut welded into the stock perch you probably don't need it
1 - 3 of 3 Posts
