1 - 11 of 11 Posts
:roflmao: :roflmao: :roflmao: :roflmao: :roflmao: :ugh: :ugh: :ugh: :ugh: :ugh:
yeah running both is cool cuz you can boost it up for a quik hot shot
me i run a manual i had a pressure switch before and i fuckin hate it because every damn time you hit a switch the compressor comes on ...........i just like to run it whenever i feel like hearin the "RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR" sound
I like manual switches also. Maybe you could modify a pressure switch so that it only will turn off the comp at a set psi but not turn it on and use a manual for that. That way you dont havto worry about over pressurizing your system when your not lookin.
do any of u have problems wit preasure switches not turning off. i saw a pic posted here of a tank blown because of a broke preasure switch. how often does this happen and is there a w ay to keep it from happenin?
well, theres no way to keep a switch from sticking..
if it wants to stick, its gonna stick...
BUT
if you use a pop off valve, it will keep the tank from exploding if the pressure gets too high.. you'd be an idiot not to use one IMO..
where do you gte these high pressure popoff valves?
Im lookin for some in the 250-350psi range
1 - 11 of 11 Posts
